Hi all
Please feel free to put in any requests for future updates and features you would like to see added. Of course we can't promise that we can deliver on all of them as there may be technical/commercial/resource limitations, as to why they aren't possible, but everything will be considered.
Thanks
Message was edited by: Thalamus.
Re-enable sticky tag
Hi
I fully agree with you, that is generally referred to in my last post. Unfortunately Sony have picked the items under Home with no thought as to their usefullness with the least used items the quickest to reach. Perhaps they were selected by monkeys?
Does anyone find that entering text into this Forum is faulty with the cursor two spaces out of position?
Hello,
Any plans for a small TV (22-26'') with a DVB-T2 tuner!? I need to replace some old portables now the analogue signal is getting swtiched off and even on small screens some SD programs look poor.
URGENT UPDATE REQUIRED...! (STRETCH TO WINDOW/SCREEN)
Please give the option "strech to window" while playing videos.. because some of the resolutions are not played properly..
For example: There is no option to stretch the video of resolutions 1280x544 and 1920x816 and many other resolutions which are not 16/9 in ratio and when i select the "zoom" and "caption" options the video is too much streched and goes out of the screen.
Any update in the coming firmware regarding this issue will be will be really appreciated.
Thanks
I would like to see a picassa ap in the photo section ( would also like 4od and itv player but everyone is asking for that already).
Add Series link function to the record to external USB/HDD would be a great addition.
Also the ability to set a record event remotely from the internet or through a mobile app (Android)
Cheers
Phil
Message was edited by: FreeviewPhil
As per Quick.Response
Good point
Does anyone have any idea where I go to ask Sony to fix existing features?
You can ask but the chances of Sony doing anything are almost nil. Even this text input part is faulty with the cursor many spaces ahead of the text. Nobody seems to care a fig.
My KDL EX series has such stupid basic faults on the software that have not been addressed in spite of many requests and no response from anybody at Sony.
Hi
Let me answer off a few of these requests
Hope this helps/clarifies
Thanks
thanks for the update
any idea of the chances of improved avi support (i highlighted what seems to be a particular difficulty above)?
thanks
.avi is the container - do you mean the codec, i.e. divx etc? Can you explain a bit more?
Thanks
