Hdd Dvd recorder RDR-hxd890 play DVD whilst Recording from tv to Hard Disc
OPGELOST
Hdddvdrp1
Nieuw
I Have a HDD Dvd Recorder Sony RDR-HXD890 (Quite old 2009) generally works quite well , it is connected to a Sony Bravia Tv (KDL-43WF663BU – 2018)
I Have recently been have problems playing some DVD (purchased in the last year), generally plays well , but when DVD Recorder Starts a Timer Program (i.e. recording to the the Hard Disc) it refuses to play a Dvd (message on the TV “Cannot play because the TV system is set differently”
When the timer is not recording  the DVD plays fine, any ideas?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Hdddvdrp1
Nieuw
hi, HDD is not full, i have decided to get round the problem and have bought a seperate DVD player, i think they have increased the anti-piracy software on DVD and the DVD thinks i am trying to copy it when i am actually recording a program off the TV
3 ANTWOORDEN 3
Piscie
Hello @Hdddvdrp1
first you need to check if disc has enough available space for the recording. You can also adjust the picture quality and try again. While searching, I came across this manual, check page 120: bit.ly/3JodHmM
If that didn't help, try to reset the recorder. The steps can be found on page 150.
Hope it helps
Hdddvdrp1
Nieuw
Hdddvdrp1
Nieuw
