The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Last Reply, I tell Accelerometer sensor will stops working after I walking or driving to other places
I think Google Now have some bugs on Android 6.0.1 because Nexus 6P and Galaxy S6 Edge have same problem too.
I found this bug on Nexus 6P forums and I try to do in my Xperia
Settings > Google > Search & Now > Voice > "OK Google" Detection > From the Google Search app and turn it off
Settings > Google > Search & Now > Now Cards and turn off Show Cards
Settings > Location > Google Location History and turn it off
Restart 1 time.
It work!
At first I did not think so too.
But I try to follow the instructions on Google Nexus forums and it worked for me
I recommend you try to do it. If not work, you can undo settings.
same issue in F8131, build 282.
it works after reboot but stops again
I'm so glad to know Sony will release a update to resolve the problem.
Please pull me out of this problem...
I uninstalled my Google-account and reinstalled it and the problems seems to be solved. (4 days of working now)
