Can't update apps while roaming
RameshGJ
recently i bought the xperia x and updated it to android 7.0 after this i got a problem. In play store whenever i tried to update any app when connected to a mobile network which is in roaming condition the apps are not being updated and also any system update which i receive is also not downloading in mobile network in roaming state 😕 seriously i am so much worried about this Slightly_frowning_Face
2 ODPOW. 2
profile.country.PH.title
MarlonUk1
have you enabled Data Roaming?
settings>more>mobile network settings>data roaming
make sure you have appropriate APN settings
and contact your network provider if they support data roaming
RameshGJ
tried everything Nothing works this pblm seems to be there for all the phones which are in nought tried google in that I came to know that pixel users also reporting this same issue
