You need to change some settings first:
1. tap longer on the screen, select home settings, disable add icons to home screen.
2. go to the app drawer, tap on the 3 dots, sort apps, own order.
3. now tap longer on a specific app and try to bring it over another, in order to create a folder.
Anytime.
