Hi
Some week ago I got a popup notification with an 'ear' icon asking
'do you allow app to record sound to improve audio?'
I think I answered yes.
But I cannot find what setting I turned ON.
If I goto sound settings I find 4 settings, all OFF.
Anyone idea what setting 'the ear' turns ON?
Can I get the question again?
br
klas
for documentation. got the answer from support:
settings/sound¬ification/accessory/automatic-optimization: ON
(then this function may use for example clearaudio+ (another setting))
Try the following: settings - apps, tap on the 3 dots and reset app preferences. Redo the operations.
Thanks for your reply.
