App to SD Card
Nas12
App to SD Card
Hello,
   Is there an App configured or dedicated just for Ultra XA for the Applications to be transfered to the SD Card? Thing is, the storage is too small and I need to transfer some Apps to SD Card to save some space.
   Thank you.
3 ODPOW. 3
Uliwooly
@Nas12
No, only few apps can be moved to the SD card, other than that you will need root access and app such as app2sd
itriste
How can i transfer my apps from the internal memory to sd card?
Tagi (3)
Hi @itriste,
If you want to move an app to an SD card you can do this in the following way. Slightly_smiling_Face
  1. Make sure that you have a memory card inserted in your device.
  2. From your Home screen, tap the Application screen icon.
  3. Find and tap Settings > Apps.
  4. Tap an app that you want to move to the memory card.
  5. Tap Storage.
  6. If the app supports changing where it's stored, a CHANGE button appears. Tap CHANGE.
  7. Tap SD Card > MOVE.
Please note that some apps cannot be transferred to a memory card though.
