Hello person,
So recently I did some home tabs idk how you would say and acsedentaly deleted my apps app how can I get it back thanks best regards-me
Hi @Hithere2 and welcome to our forum!
If you haven't already sorted this out, press and hold on an empty area on your homescreen > tap on Settings in the bottom right corner and disable the setting called "Enable swipe-up". When this setting is enabled, you need to swipe upwards on the homescreen to access the app drawer as the icon is removed.
I hope that helps!
