Button disables audio on call
Cinzia84
Visitor
Hi, I often turn off the sound during a call by voluntarily clicking the mute button with a part of the face. Is it possible to remove it?
Pulsante disattiva audio in chiamata
Buongiorno mi capita spesso di disattivare l'audio durante una chiamata cliccando i volontariamente con una parte del viso il pulsante disattiva audio. È possibile rimuoverlo?
3 REPLIES 3
Uliwooly
@Cinzia84
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I'm afraid not, does your phone has a protective case film or glass that it's covering the proximity sensor?
Cinzia84
Visitor
No no protective film
No nessuna pellicola di protezione
Uliwooly
@Cinzia84
Could you test the proximity sensor?
Settings > About phone > Diagnostics > Test
Oreo
Settings > Support > Tests
