Xperia xa screen mirroring problem
Ravi77
I m tired to screen mirroring with my samsung smart tv i resat my phone but not work
Tagi (1)
19 ODPOW. 19
@ravi7477 Would you mind sharing which TV model you have?
Please bring up any questions about getting your phone exchanged with your Local support team.
ravi7477
Any xperia xa user connect there's phone to tv with screen mirroring option if not so can u ples chak. Because i m tired to connect my phone with tv using screen mirroring option. I also go services canter they no solve my problem.
Uliwooly
@ravi7477
Don't create duplicate posts, thanks
loveforxperia
sir, i have a same problem@ravi77 told you. i have xperia xa dual and a samsung led UA40J5300AR and it has  screen mirroring option. please help.
Hi @loveforxperia, sorry to hear that.
Could you send me your device's IMEI in a PM? I will then forward this internally.
Thanks!
aromohit
Me too facing the exact problem regarding screen mirroring with Samsung 32j4300. My Xperia. M used to work perfectly fine when I used to mirror its screen. But this is not the case with my XA DUAL... Please fix this.. I think it's a software issue from Sony. Please update it
VladimirLen
I have the exact problem my cousin's xperia m4 screen mirror works perfectly fine with my Samsung j3404 tv. Also his girlfiend's xperia mirrors good as well as my tablet. But why can't my xa mirror at all. It keeps saying that screen mirror is off after loading for a few minutes. This is indeed a software issue. Please fix this as soon as possible. It's already been months now since i bought this phone and the screen mirror still cannot work.
ravi7477
If any one solve this problem than please reply me and one more thing is that when i try wifi direct option and try cast option in album app its work ok but not 100% work some time casting also disconnected after 1 hr but it's ok
Amsingh
I have sony bravia w56d series tv. When I connect my XA ultra dual phone through screen mirroring, screen freezing and sound freezing problem with in 15 to 30 seconds continuously from only 6 to 7 feet distance. This problem increase after update 36.0.b.2.146 and previous software of mobile, this problem was available but presenty increased. Please resolve immediately.
Amsingh
