Bluetooth pairing problem
earthquake61
Visitor
Hi,
with my Z2 it is possible to pair one device.
For an example:
I pair my headset and connect it -> no problem.
problem: when i want to pair for e.g my car device there is no result when i search for it.
when i delete my headset and search only for the car device. it works.
it must be bug becauce with my Galaxy S4 it was possible to pair more devices.
any solution?
3 REPLIES 3
Sam
Legend
Legend
There should be no problem with this unless you are actively connected to the headset at the time. You would have difficulty connecting to two devices at the same time if they both perform the same function.
What are your thoughts about this forum? Let us know by doing this short survey.
earthquake61
Visitor
But there is a problem. I have massive problems to pair more devices. When one or two devices are paired (without an active modus) the Xperia Z2 does not find further devices.
For an example:
I use the Sony smart band SWR10. connection ok
when i pair my headset Plantronics M55 and connect it: Ok, after disconnection and searching for further devices e.g my Bluetooth Heart sensor the Xperia Z2 does not find it. The same e.g with my car device. It is very difficultt.
With my Samsung S3 or S4 there was no problem. Easiely paring and conneting, thats all.
And now?? What can i do?
earthquake61
Visitor
Seems to be it's solved ๐Ÿ˜‰
