camera issue
welt0n
Visitor
camera issue
Since I bought my Xperia Z1 Compact that its camera suddenly stop to work. It just freeze and I have to restart the phone if I want to take any picture or record any video. There is anyone that knows what is going on about this problem?
1 REPLY 1
Thommo
Genius
Try performing a system repair as this will often fix issues - This will factory reset your phone or should the issue continue then you may need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
