Have been using Xperia Z1 for 8 months now and one problem that always gets on my nreve is the dust that accumulate's between the aluminium frame and screen. This indeed is a flaw in design. I have tried water spray but even that works only for loose dust. I could have used a needle or something, but that poses a threat to screen being scratched and is not a reliable solution.
Any Sugestion's?
Note - I am seriously dissapointed with the Xperia Z1 aluminium frame. I would even appreciate the Xperia Z frame against Z1.
Use a soft bristle toothbrush or a brush of a similar nature - That's what I use and it causes no scratches
Haha.. I do that.. But there is some hard stuck dust that does not cme off with a toothbrush. I'd say they did better workaround for this in Xperia Z3
