hi all
on my experia e1 i have a little green man with his belly open and a red triangle on it ,i cannot ge the phone to work at all what is wrong
You need to perform a system repair - This is often caused by a failed update or you have tried to modify your device, Have you unlocked your bootloader if not then follow the below
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
