my xperia p keeps restarting. i have tried all the power and volume button combinations.yet still the problem persists. what can i do.
You can also reboot your phone on safe mode, and w/o the SIM card, if it doesn't reboot loop then its an app or the SIM card
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
running sus on windows 7....sus cant see my phone
make sure to charge your phone
hav checked the link out.the suggestions in there didnt solve the problem either. also the sim card works perfectly in other phones
try my suggestion just remove the SIM card and check again, if that doesn't work nor repairing your phone with SUS or PCC then you will have to stop by a Sony repair center
tnx for the help....appreciated
Anytime
i have the same problem with you
how can i fix this??
