I cant find my front camera
Haya
Visitor
Hi Sony Mobile ME .How r u ????
I want your help plz
I used Sony Xperia Z2 in the pool & steam room
& Know I am facing two problems
1-I cant find the front camera ?
Like really cant find it .There isn't even the switch button from face to rear
As if there wasn't a front camera ever
Plz Help
4 REPLIES 4
Thommo
Genius
Could be that the connection between the two ie: board and camera has failed so the option will disapear - You could try a system repair and if that fails then your options are to either return back to the place of purchase or contact Xperia care http://www.sonymobile.com/gb/support/contact-us/
Rickard
Master
Sorry to hear about your phone.
I recommend that you follow the suggestions from
foxngn
Visitor
hey , how was it ? you need to send back for RMA ?
this piece of **bleep** of my also had the front camera logo dissapeared.
Haya
Visitor
Hi Foxngn Plz If u found a way to return the front camera logo & to make the front camera works Plz inform me
My front camera is still not working
