Hello, In Sony Xperia M Internal storage device cant be display in PC System. But it shown only SD Card Device Only.. So kindly check the problem and reply soon... And I tried a new USB cable but its shown only SD Card .. Thanking You
Go in settings of your Phone, find Xperia connectivity, and change USB connection to MTP. You must unplug your USB cable before you can change to MTP mode.
