Sim card
liefrid
Visitor
Sim card
i get no network coverage using my sim. but it works fine on other phones. and other sim cards ( same carrier as mine and even different than my carrier) works on my phone . So why is the only sim not working in my phones is mine ?
help plz
15 REPLIES 15
aayonara
Visitor
I think that best thing is to request new SIM card from your network carrier. Maybe it's litle defected and SP SIM reader have problem with it. I don't know what can be other problem. Does your phone say that no SIM is insertted, or network is not avaiable?
Thommo
Genius
Is this a new device or a used device - I ask because if used then it could be a lost or stolen device that has been reported and blocked from using that network
liefrid
Visitor
it used to work fine. this happend when i changed the broken screen.  in between i was using my sim card on other phones
liefrid
Visitor
it says no network availble.
aayonara
Visitor
If it's so, problem is with your network operator. You must see with them. I think that you need new SIM card. They can do a duplicate for you in no time.
Just one more question: did you try in settings to setup only to 2G network? Does this do any good? Any changes?
liefrid
Visitor
i  tried only 2g ..only 3g. manual search for network ( found the network but couldn't register)
aayonara
Visitor
Defenatly question for your network operater. Try with new SIM. Your phone read all others, so it's hard to beleve that mailfunction is on your phone. Good luck!
Tags (1)
Thommo
Genius
Sounds like a Sim card issue or network issue - The Sim may work on other phones but this could be down to sensitivity of the sim reader - I'd have this checked out at your network providers store or if it is the network then contact them to see what the problem is or even ask if they have blocked your phone for some strange reason
3xperia
Contributor
Liefrid's SIM card doesn't work on XSP but works fine on other phones. And you guys blame it on the SIM and network carrier that might have blocked it? That's so illogical. LOL
