not charging while connected to the wall charger
namanrajput
Visitor
My xperia sp sometime stops charging while connected to wall charger.. The same tging i had with my xperia ion .. And even i got changed its battery but the problem still persist in the xperia ion..
When ever my xsp is chargingand is near about 72% charge it stops charging and charging led turns off.. And now it has started taking more tym than normal in getting fully charged from 4%.. I m very much satisfied with this phine.. But i wasn't satisfied with my xperia ion.. Which i had to sell at a great loss ..
Now my xperia sp is still under warranty.. Any body please help..
2 REPLIES 2
namanrajput
Visitor
Edit.. I even tried that hard reset (3 vibration), and did the factory reset even... Cleared the data and cache from eco controller from apps menu in settings.. And yes when i reconnect the charger.. The charging starts with out any problem..
I m worried because due to this same problem my xperia ion was completely destroyed..
deejay
Visitor
Try with different charger if still you face same problem then take your phone to Sony Service center.
