WiFi doesn.t start
edika99
Visitor
WiFi doesn.t start
Randomly the WiFi stop to work and turn off itself and won't start again.
The only way is to tunr off the phone and turn it on again.
4 REPLIES 4
Thommo
Genius
Do you have stamina mode turned on? you also may want to consider a software repair as you may have an app causing this issue
edika99
Visitor
Yes I've turned on Stamina mode some days ago but the problem was present also without stamina mode.
What you mean with Software Repair? Which app would cause this issue?
edika99
Visitor
Please can someone help me with this problem?
BeadyEye
Visitor
Software repair is found in Sony Pc companion. Download and install that program. Then backup your data. Then perform a software repair. It might fix it.
