Scroll function in Walkman.
Lazyloonie
Visitor
I don't know if this option exists already and u have to turn on but I would be great if a person could scroll through music by letters like u can inside ur contacts.
3 REPLIES 3
Thommo
Genius
You mean Album names or Artist names - It's already there as long as your songs are tagged - open Walkman app and tap on the walkman icon in the top left the open Library or if you tap on the 3 dots in the top right then open settings and turn off Music unlimited then as above you can open your library of albums without going through several options
Lazyloonie
Visitor
It does put things under the letter. What at I was referring to is say u have a 1000 songs and u r looking for one under S. U have to scroll down currently through 800 songs to get there. In contacts it has all the letters on the side so u can go directly to S in a split second.
Thommo
Genius
Then on the top line is a circle with a line at an angle going to the left - Tap that and type the 1st few letters then all songs and albums with those few letters appear
