The little black thingy where you put the Sim card is nowhere to be found.(I lost It) So is there a way I can get it or can I use the Sim card without it? That's it, thanks and stay awesome Sony!
Hi SoloRider
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you try contact Sony Mobile directly, they may be able to help you get another SIM tray for your device. Use the link below to find there details.
http://www.sonymobile.com/global-en/support/contact-us/
I hope this helps.
Any time, let me know how you get on.
