smartchwatch 2 charging problems
23nr22
Visitor
 This my replacement(new) SM2 smartwatch and have charging problems. It initially charged ok and now it wont charge past 45% from zero. I am using correct USB to laptop connection and USB cable. This was the same problem I had with the origianal. Did hard restart /rest but on luck.  Do see the battery icon with the lightning bolt.But not the battery icon showing the % charge .
Tags (1)
1 REPLY 1
Uliwooly
Sorry to hear that, please do contact your local Xperia Care
http://www.sonymobile.com/global-en/support/contact-us/
