Sony Xperia z2 not charging
Alice95
Visitor
Hi um sorry if this is posted in the wrong place, I noticed my phone was very low on battery which it never normally is so went to put it on charge and came back an hour later to find it hadn't charged at all and had gone down.
My mum also has a sony phone so I am currently using her charger and after not charging with that to start with it's slowly charging with hers - the phone is less than 6 months old and now Im wondering if it's the phone or charger? It's not the charging port as I tried with both my dock and inserting the cable into the side and neither worked with my charger.
Do sony sell replacement chargers or am I going to have to ring?
Any help would be great- thank you!
1 REPLY 1
Thommo
Genius
If it's just the charger then Google EP880 and you will find lots of places that sell them - If you think it's something else then you'd be best contacting Xperia care or returning your device to the place of purchase http://www.sonymobile.com/global-en/support/contact-us/
