Hello i have three problems with my Sony xperia z1
1-vibration do not work
2-cannot find the front camera icon so i'm unable to use it anywhere tell me if it needs to be installed by driver or something.
3-when i close some applications they start automatically again after few seconds like facebook and some other applications.
It is not recommended to backup so much data via PC companion.Use MTP connection mode,it should show up internal memory.
I changed the usb connection option on my Xperia z1 to MTP but when i blug in the usb cable the option icon disappears and comes up the usual phone storage again.
In this case,get in touch with a staff member and see if he can help:
http://talk.sonymobile.com/t5/Welcome/Community-users/m-p/634967
Please try uninstalling/reinstalling the device:
Open Device Manager on your computer to reinstall the driver for your device while your device is connected with your PC via a USB cable.
Microsoft Windows Vista and 7 users
To open Device manager on your computer
Click on the Start button.
In the Search box, type device manager, and then press enter.
Microsoft Windows 8 users
Click the Desktop Tile to open the Desktop.
Click >> at the bottom right of the taskbar.
Select Control Panel from the Menu.
Select Device Manager from the list of control panel items.
Note: If you do not see the screen with the Device Manager option, click the View by drop-down menu and select Small icons.
Microsoft Windows XP and 2000 users
On the desktop, right-click on My Computer and click Properties.
In the System Properties window, click the Hardware tab.
In the Hardware, tab click the Device Manager button.
To reinstall the drivers for your device
Scroll down to the Universal Serial Bus controllers (USB section) of the Device Manager window.
Look for an MTP Device: Media Device, Unknown Device or any other reference to your phone. Click on this entry and choose "Uninstall" whilst leaving the device connected.
Wait a few minutes, and the computer will reinstall the drivers for the device.
Now, the phone is accessible via Computer/My Computer on your computer.
I backed up my photos and videos using Sony pc companion i repaired my phone and still vibration and front camera do not work like i have to send the phone back but unfortunately i have no warranty i guess i'll have to use it without vibration and front camera (it is probably broken).
Now i have another question please i want to know how to install apps dirrectly to SD card and move installed apps there. Android 4.4.4
You cannot move apps to SD,it is a restriction from google.
My internal storge is full while my SD card is eighty percent free inclouding that i moved all photos and videos there. is it possible that i install an app in my internal storage then move the android/obb/'folder' to SD card/android/obb/'folder' will that work? I also heared that if you root your android 4.4.4 you'll be able to move installed apps to SD card??
Only by rooting you will be able to do that.For rooting,look on XDA devs forum.
