Hi all,
I have changed mi phone operator, the SIM unlock was done by code.
And now the functionality of Portable Wifi Zone and USB (tethering) is not working.
What could be the reason? any solution?
Thanks guys.
Do you have data on with your new carrier/network? does the new carrier/network allow you to tether your data?
Yes, data and carrier works fine. I have contact my new operator and said me that tethering is possible, there is no restriction.
Do you get an error?
No.
I have checked the APN connection settings for my new operator and it is ok. I have tried with several APN types (default or dun) but doesn't work.
My phone is updated by PCCompanion. But the problem persists.
