Xperia M Problems
francisfrayne
Besucher
Xperia M Problems
I have had my Xperia M for about 6 months now and everything has been fine. But when I bought a SanDisk Micro SD card I can not transfer the data (such as music photos etc) from the phone to the micro SD card, I just get an error message.
I can no longer download apps from the Google Play store because apparently my phone does not have enough storage space. I do have enough space because I have checked and have even deleted some apps to be doubley sure.
Could you assist me with these two problems?
Thanks,
2 ANTWORTEN 2
Thommo
Genius
Are you able to connect your phone to a Pc and transfer these files then before deleting the files from internal check them on the SD 1st - Once you are sure the files are ok then delete them from internal to free up space
bubimir13
Besucher
Thanks,
Did you try inserting your SD card in SD card reader with PC connection and see if its working? If not, see if you can Format it in FAT32, it should work.
About Play store, try force close, clean cache and data, then restart the phone and try again
