Hi,
Updated my Xperia P recently to JB.Was Working fine for a day or two then suddenly the phone shut down automatically.Sent it to Service Center n got the software updated .Still the phone shuts down as soon as I insert a Sim card.The service center guy asked me to change my Sim card.I did it but the problem persists....It runs perfectly well without a Sim?What to do ...????
What happens exactly if you turn off the phone, insert your SIM-card and then try to start the phone?
Have you tried another SIM-card and tried making a repair of the phones software in PC Companion?
I have tried that too and its not working.. without the sim card phone works perfect even wifi..
but as soon as i insert the sim card phone restarts and immediately turns off..
What i understand is it is some network related problem..if the phone put on Flight Mode then also works well..
It get turned off whenever it searches for the mobile network..
I have purchased it from Saudi Arabia so the local service centers are not even ready to take a look on it...
May i know what would be the actual problem ?? Would it be network locked?? what should i do now??
Unfortunately if the SIM works in another phone and another SDIM in your phone gives the same problem then I am inclined to believe it to be either an odd software issue or a hardware problem with the SIM reader. If you have already tried a software repair then I can only advise you to return the phone so that it may be looked at sorry.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
thanks it helps me a lot.. it fix my phone for free "__ thank u again garry
why i cant browse using my phone after i do thje steps . help me.
You likely need to source the internet settings again: Main Menu > Settings > Xperia > Internet Settings > Accept.
Good 1 bro worked for me thanks allot
Thank you very much sir! I was pretty messed up with this problem. Tried what you said and my device is working fine now. Stay blessed man.
Hi AkashTan and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Can you please elaborate on the exact problem you are facing and which of the soltuions above you have tried?
