No delivery reports
Maryj
Visitor
No delivery reports
Translation via Google Translate:
There is no longer the option delivery reports in the messages, it was there in the xz but not in the xz1, someone would be it how to activate it because even following the user guide no way
Thank you in advance for your answers
Il n y a plus l option accusé reception dans les messages, elle y etait dans le xz mais pas dans le xz1, quelqu un serait il comment faire pour l activé car meme en suivant le guide utilisateur pas moyen
Merci d avance pour vos réponses
12 REPLIES 12
profile.country.US.title
Qatrium
@Maryj
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
Open your Messages app -> tap on the 3-dots icon on the top right corner -> Settings -> Advanced -> Enable "Get SMS  delivery reports".
Hope I understood your question correctly after translation.
Maryj
Visitor
No, in the xperia z1 from Bouygues there is no option, is this due to a new email application ??Screenshot_20171113-202208.png
Tizer
Contributor
I do not think the new Google messaging app allows delivery reports. I have the same problem with my xz1c and I'm with Vodafone UK. It worked perfectly well with my z3c which had the Sony messaging app.
I hope that Sony will go back to their own messaging app, which was far superior. I sometimes also have difficulty reading messages with the new app because the text has white lettering and some of the background colours are flourescent and there is no option to change this. With the old Sony app the background colour was set by what theme colour you set.
alaa_ghribi
Visitor
That's really strange from Sony to ignore that Nokia 3310 feature! I'm so upset...
Volente
Visitor
Is this what you mean? I have it in Norway
Duri
Visitor
Seems like the Advanced menu of the Messaging App differs for the firmware customization. On my German single SIM XZ1 i have the switch "Get SMS delibery report", but other 2 menu points are missing: Enhanced features and Wireless alertsScreenshot_20171119-050545.png
gregoryopera
Contributor
Perhaps use a different SMS client?
If you really need delivery notifications and it is not supported by your current firmware, then this might be the best way around it...
Tizer
Contributor
Thanks Volente and Duri, It looks like Delivery reports, Wireless Alerts and Enhanced features are not supported in the UK.
Thanks also Gregoryopera, I may give OKSMS a try. Hopefully it will work ok with Oreo.Screenshot_20171119-143027.png
Maryj
Visitor
Not for France may be at the next update of the messaging software
