Orange SD card warning on camera screen
Steve-O-1797
Visitor
 I'm not entirely sure what this little error icon is about and trying to Google it nothing comes up either. Any ideas? I currently have a 64gb micro sd installed in the tray.
5 REPLIES 5
profile.country.US.title
Qatrium
@Steve-O-1797
Maybe you're running out of space on the SD card?
Steve-O-1797
Visitor
@Questerwrote:
@Steve-O-1797
I thought this initially as well but I still have over 50 gigs of available space.
Qatrium
@Steve-O-1797
My next guess is that the SD card is not formatted properly. Do you have your default save directory to SD card and you take pictures normally? If yes, are they viewed correctly in Album app?
Steve-O-1797
Visitor
Apparently if you dismount the SD card and remount it this goes away... Thanks for the help!
Lord_viridis
It can also be a warning that the sd isn't fast enough for some camera features such as burst or 4k recording.
