Quick questions, quick replies; ask anything about the XZ Premium!
Emir1
Hero
Hey everyone! The purpose of this thread is to ask anything that you wish to know about the XZ Premium; other users owning an Xperia XZ Premium and forum staff will do our best to reply! Slightly_smiling_Face
As an example, prior to purchasing an Xperia XZ Premium you may be wondering if someone has tried out a specific third party app or feature on their XZ Premium, and could tell you a bit more about the compatibility and functionality as the app may important in your daily life. Staff and other users can come in and reply and let you know how it works!
The goal of this thread is to help each other out as a community. We will try to moderate this thread so that any new threads with a fitting question will instead be moved here, while we of course keep support threads the way they are now.
NOTE:
Support related questions, such as raising concerns and troubleshooting are best suited in a different thread. Please try to see if there is a thread regarding your concern, and if not, feel free to create one! Slightly_smiling_Face
501 REPLIES 501
NathanL
Visitor
I fowarded my question to hear with hope that someone can answer me, many thanks!
I just got a brand new XZ premium phone from ebay and not sure that I have a problem with screen rotation or its normal for everyone using xz premium here. So when I use the auto-rotate mode the phone works find but when
I rotate my phone to landscape mode and lock the rotation, the screen automatically backs to portrait mode and won't allow me to watch the contents in landscape mode by anyhow. In other word, I can't keep the screen in landscape mode when using my phone in different dimesion while locking the screen rotation. Since my previous phone XZ allows me to lock the screen in landscape mode, so that makes me even more confused.
Lord_viridis
@NathanLam94
You've already asked about this in a separate topic, please don't cross post.
Thanks.
Wahi5
Visitor
thanks for the answer 😉
azzido
Enthusiast
@najodleglejszy wrote:
...which effectively means that there's no FM radio.
... which effectively means physically there is FM Radio and still we can have it and it is only sony who decided to disable it no matter people wants it, how rude of them is this? Sony must enable it as it was in the past or still is for low end Xperias...
harutsuki
Visitor
Can't boot to main meun. Boot loop at xperia logo.
*no rooted
profile.country.US.title
Qatrium
@harutsuki
Try to perform a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory, so that means you'll lose and stored data on the internal memory and all apps will have to be re-installed.
Follow the steps given in blue links, and keep us updated.
Abpzo
Visitor
Hi all,
I want to ask about screen blinking. My xzp screen sometimes blinks although i turn off adaptive brighness, so it makes me uncomfortable. I don't know how to solve that. Can anyone give me advice in this case?
najodleglejszy
@Abpzois the screen brightness is actually changing or is it just contrast/saturation of colours fluctuating? because it could be that what you're seeing is a feature called Qualcomm Assertive Display https://www.qualcomm.com/news/onq/2015/02/20/assertive-display-power-efficient-technology-thats-easy...
Abpzo
Visitor
The brightness change to high and low and high and low, like we move the brightness slider. But if you can advice me how to disable Assertive Brightness, i will try to disable and see if this problem happen again.
Thank you very much
najodleglejszy
@Abpzoit's not possible do disable Assertive Display. but since you're saying it's actually the screen brightness that's changing, then I don't think that's it. you could check if the same thing happens in safe mode.
