Screen duplication problem
Borofer35
Visitor
Hola escribo para ver me pueden ayudar, resulta que tengo un tv samsung compatible con screen mirroring y con el sony xperia xz funcionaba perfecto pero con el sony xperia xz1 cuando duplico la pantalla se pixela la imagen en la tv, es como si le costara reproducirlo. Queria saber si le pasa alguien mas y si tiene solucion. Gracias
Hello I write to see can you help me, it turns out that I have a samsung TV compatible with screen mirroring and with the sony xperia xz it worked perfect but with the sony xperia xz1 when I duplicate the screen the image is pixelated on the tv, it is as if it cost him to reproduce it . I wanted to know if someone else happens to him and if he has a solution. Thank you
GT
1 REPLY 1
elitte62mark
Visitor
Me too,same problem,I don't know how to resolve!
