- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
The camera of my Xperia XZ doesn't work at all
I have an XZ and since 2 days my cameras aren't working, neither the lintern. Sometimes pops up a box "Error! Camera not available!" Any suggestions on what might be causing this issue? Or anybody else having this issue/had this issue and knows of a fix? I had cleaned the app cache, restarted my phone as usual and on teh safe mode, and nothing worked... 😞 Any suggestion?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You can try a couple of steps to check your camera.
Go into the service menu by opening phone app and dialing *#*#SERVICE#*#*
go to service tests, and select main camera.
It will then show if the main camera is working.
I expect it won't show anything because you stated safe mode fails to work too, so I'd suggest backing it up and wiping it, then performing a full factory repair installation using Xperia companion.
If after this the camera fails to work, it will need a repair to the camera module.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Jezzups, since you've tried safe mode already and it didn't work, you can try to force stop the camera and uninstall its updates from Settings - Apps - Camera. Also, make sure to allow all the permissions.
Cheers
