Hi @trashcan,
I would recommend using the finger print feature. It's very easy to use and is also extremely handy. No more having to type in a PIN, pattern or password to unlock the phone every time I need to check something real quick.
Worst case scenario you always have a backup screen lock to use if your hands are for example dirty and it's hard for the phone to read your finger print.
I hope that answers your questions, if not let me know!
I've not had a problem with the fingerprint reader, been flawless so far
Hello everyone!
I'm happy to see that most of you are very happy with the finger print feature and that is working great!
@Xzs, Does this happen every time you unlock the phone? I would recommend that you reboot your phone in safe mode and see if you experience the same behaviour here.
Let me know how it goes!
