Xperia XZ 5Ghz Tethering
chewdz
Is there any option to choose which band I can use the tethering? I can't seem to find any settings for that.
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Jonas
Guru
No worries, I totally see your point.
I will make sure to forward it as user feedback. Slightly_smiling_Face
4 ODPOW. 4
Uliwooly
There isn't, I'll double check but I thought it was standard accross android
Jonas
Guru
Hi @chewdz,
As @uliwooly wrote, there is no setting for this.
If you want I can forward this internally as user feedback.
Let me know if you want me to do that or if there is anything else I can assist you with! Slightly_smiling_Face
chewdz
Hi @uliwooly and @Jonas, Thank you for your replies.
I'm asking because I believe it is a feature in Marshmallow and I'm using it in CM13.
With the 5Ghz capabilities in Xperia XZ, I'm sure users would like to have the option to tether as 5Ghz.
Please forward this internally as user feedback and hope that it will be implemented Slightly_smiling_Face
Thank you!
Jonas
Guru
