- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
It is really annoying because it pauses automatically any media i play. Is the phone detecting headphones even when i actually domt connect one? The phone is really gettig hot because of this
Any solutions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @ahmdaini, sorry to hear about this.
It really does sound like the device thinks a headset is connected and then disconnected and then it repeats this circle.
If you start the FM radio application, does it show the message about connecting a headset and then it disappears > reappears and it continues in a cycle?
If that is the case, go to Settings > Apps > Smart Connect > Storage > Clear data > OK and then restart the device.
You can also take a tooth pick or something similar (not too sharp) and try and clean the audio jack in case there is any dirt inside of it.
Let me know if that helps!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey it works good as new now, thanks a lot! 😀
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi again @ahmdaini,
That is awesome news!
Was it Smart connect or cleaning the headphone jack that solved it?
Thank you and have a nice day.
