- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
I have an Xperia Z, with a cracked screen that is not responding to touch anymore.
Tried to copy files from Phone to PC, but I'm not able to see the sd-card or files.
Tried the PC Companion. It sees the phone, but say's it has to be unlocked. Which is not possible anymore.
I also tried MyPhoneExplorer (which seems to have spyware on board according TrendMicro), but also no success.
Please help, because I need my 1100 pictures....
Kind regards, Jelmer
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@marj
You can enter your PIN and unlock the phone by connecting a computer mouse to the phone using an USB OTG adapter. When it's unlocked, remove the mouse and connect the phone to your computer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thank you!!!!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Rickard
Will connecting a mouse work to unlock the phone if it is a pattern/swipe lock?
If not, do you have any other suggestions please?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, it works for pattern and swipe.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Amongst the 1000's of cords and connectors I have I found 1 of these bad boys and BOOM - tiny little mouse arrow appeared on the screen and then BAM, problem solved. Now I'm off to replace my phone... again. KABLAMMO!
Cheers!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Where did you get that!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same issue but the phone is not recognized after swiping with mouse. My replacement phone from insurance has arrived, so I have tested my OTG cable and mouse swipe on the new phone to make sure it worked. Recently, I selected "charge only" when prompted the last time I had plugged into my computer. Would this be causing my PC not recognize the Z3? and is there a work around? My screen on old phone is black with a few color lines on it. My last attempts have been without a SIM card in the phone, would that make a difference?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You don't need any SIM card in the phone to connect it to a PC and it should not be releated to charge only.
Did you have a PIN, pattern or password set on the phone and are you sure it's just the display that's broken? To test this you could insert an active SIM card (without PIN code on it) and try calling the phone or if you have an MHL-adapter you could try connecting it to a TV to see if it's on and working.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
HI i have xperia z1 and my screen got cracked and touch is not working.Can anyone please let me know how to take backup without unlocking
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
