No sound from media apps in headphones
HenrikE
Visitor
Hello,
I bought an Xperia Z5 almost a week ago, and I'm very happy with it.
The first day or so, it worked perfectly fine. Now however I'm not getting any sound from media apps in my headphones.
I've tried Youtube, Netflix, Spotify and the preinstalled media apps such as Movie and Album.
Also tried with another set of headphones, still nothing.
I can hear keytaps, ringtones and selection sounds though.
Without the headphones everything works fine.
Is there a setting I might have missed somehow?
Tags (3)
26 REPLIES 26
zaneali
Visitor
Xperia Z5 is not playing the sound through the headphones given with it, phone is detecting it but not playing sound through them, instead still playing through the speakers, pls help
Tags (1)
CameronT
Champion
Hi @zaneali,
Welcome to the community.
Does this happen with any other headphones?
profile.country.GR.title
sfortis
Member
something is going wrong with MM and 3.5jack device detection... most probably detection using ohm resistance is messed up! headphones not working, line out issues...hmm...
Christofer
Champion
Hi @HenrikE,
First of all, when you have a headset connected, can you go to Settings > Sound & notification and make sure that Media volume is turned up?
Could you also test your phone in safe mode and see if you still get no sound in the Music or Album app?
HenrikE
Visitor
Thanks for the quick answer, but I'm afraid neither solution worked for me.
I have checked the volume settings in the Settings both with and without my headphones, and all volumes are turned up to max.
I did restart in Safe mode, but I'm still not getting any sound from the preinstalled app Album.
Tim77
Visitor
The phone jack is broken common problem that song are ignoring as usual. I downloaded soundabout from the app store and use that to force sound to the jack. Its a temperamental workaround
chnwh
Visitor
I have been having a similar issue for the last week or so.  The phone doesn't recognise the headphones are connected so the radio won't work.  I can force my Spotify through the soundabout app so don't think the Headphone Jack is faulty.
I've done the android update and a phone repair through PC Companion.  Any ideas?
jeocava
Visitor
I also have the exact same problem as @HenrikE. I can hear keytaps, also the radio is working fine. The odd part is, it is working with spotify and facebook app once and then suddenly after some days, it is not working at all. Some people thinks that this is a harware problem but it's not.
Please relay this to the higher ups. Thanks.
Tags (1)
HenrikE
Visitor
Just wanted to add that I tried with bluetooth earbuds, and they're working perfectly fine.
At the moment I have literally no idea what's causing this issue.
As I can hear keytaps in my wired headphones, I can't really believe it's a hardware issue, but as the media is playing through bluetooth, I don't think it's an app stopping media playing either.
