Re: Xperia_z_camera_problem
SOLVED
prabhujon
Visitor
I have updated my xperia z to 10.1.1.A.1.253 and started to enjoy my phone well. When I opened my camera app I was shocked to see my camera is only viewable to two third of the screen and the rest is black. i tried with front camera it works fine,  the pictures  taken are also of same size when viewed in the album. can anyone please suggest me to solve this issue.
I have attached my screenshot of the camera app
1 ACCEPTED SOLUTION
Accepted Solutions
Henke
Contributor
It is because you have chosen a resolution with 4:3 format.
Start the camera and go into the settings, change the to a resolution with: 16:9 format.
2 REPLIES 2
Henke
Contributor
prabhujon
Visitor
thank you...
