Screen Lock face down
chris_s2015
Can anybody help me to change the setting to stop the device locking when placed face down ? I have looked through security and power management and none of the options seem to work.
Thanks
Tagi (2)
9 ODPOW. 9
profile.country.RO.title
_alexdon_
That is not available on Z1 as far as I am aware.
alexdon
chris_s2015
I had a play around in settings, and it seems to be something within Stamina. There a no separate settings for this in Stamina however, so the only way to stop it is to turn it off
_alexdon_
You lost me with this. The option is not available on Z1.
alexdon
profile.country.US.title
Qatrium
You might have a 3rd party app causing this, try to see if this happens in Safe mode:
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
chris_s2015
Hi Quester, it seemed to be linked to power saving/stamina. I'm not sure why as Alexdon mentioned, the option isn't available on the Z1.
Turning stamina off has solved the problem, so it is not an issue now.
Qatrium
I couldn't recreate this on my Z3, neither Stamina or Ultra Stamina modes causes my screen to lock when mobile faces down.
Did you try to clear cache of Stamina app?
- Turn off Stamina mode from Power management.
- Go to Settings -> Apps -> All -> Stamina mode -> Force stop, Clear data and restart your phone.
chris_s2015
I have tried this too, it still locks. I have found someone else in my office with a Z1, that is also doing this so it is not isolated to mine.
lukeflegg
I'm getting it on my Z3. Never noticed it before but now, I lie on my back, phone above my head, and every 3 seconds; black screen.
MarioZ
Since this thread was the first hit on google when I search for the same issue, I just want to add that for me it was the "Gravity Screen" that I had installed, that although it's amazing, you need to be careful with the options.
The option that I had to turn off (set to zero) was the table sensor angle. It defaults to 15 degrees but setting it to 0 will disable the feature.
Thanks for recommending the safe mode boot that guided me to the right direction ! (I was looking in the phone's settings at the beginning and couldn't find the "turn off screen when phone is facing down" option.)
