Hello
I've updated my mobile phone SIM card is not recognized, unfortunately, when I turn on the "SIM network unlock PIN" wants!
Please help me
My phone is Sony Xperia Z5 Dual
Thanks
Hi
It seems your phone was locked to a network operator and was unlocked by third party and not the network operator itself. That's why a software update triggered the Sim lock mechanism again as it wasn't locked permanently as is the case when unlocked by operator. Sometimes it happens that a phone unlocked by the operator also gets locked again after a software update. In that case, you should enter the same unlock code you used to unlock it before.
So a few questions.
How did you update your phone ?
From where did you buy the phone ?
Your phone is branded to what network operator ?
Give as much details as possible.
Thank
1. Using Flashtool production
2. I have bought from online store
3. I do not know, I've been using two SIM cards (MTN Irancell and MCI)
Did you update using flashtool ?
That's the reason.
Flashtool isn't an official Sony's software.
The firmware ( complete software ) in your phone that came pre-installed along with it was probably locked.
Flashing another firmware using flashtool on a phone branded to network operator triggers the sim lock mechanism.
However if you updated using Xperia Companion, your phone would have been fine.
Here is that http://support.sonymobile.com/global-en/tools/xperia-companion/
Ok, so give me the online link from where you bought the phone.
I will see what operator it's branded to.
Yes Using Flashool
SIM for Iran and for operator MTN-Irancell
Please tell me how can I solve this problem?
I have purchased Web:
Send me the IMEI number of your phone in a private message.
Dial *#*#7378423#*#* in phone pad > service info > software info > take a screenshot and post it here.
Sony will not be updated with program
I have sent a personal message
Thanks
Please help repair and after-sales service is here!
Hey
I saw all your messages.
You have flashed using flashtool and it's an unofficial software. The warranty of your phone is void already.
You are allowed to use only Sony's tool that is Xperia Companion http://support.sonymobile.com/global-en/tools/xperia-companion/
Do one thing now. Download Xperia companion on your PC and install it. Connect your phone and see if it updates your phone to the latest build. I saw from the screenshots that you're running an old build and an update is available for your phone.
Yes, but with Sony's software was not updated! And error messages have had and we have to use Flashtool production
Do not consider another solution for us?!
