SIM network unlock PIN
MaHDi_011
Visitante
Hello
I've updated my mobile phone SIM card is not recognized, unfortunately, when I turn on the "SIM network unlock PIN" wants!
Please help me
My phone is Sony Xperia Z5 Dual
Thanks
44 RESPUESTAS 44
oMiD94
Visitante
I Have a same problem
Please help us
Etiquetas (1)
Nabeel
Máster
Do you guys not know to which network your phone is branded to ?
See on the box of the phone and check what operator branding is present.
Put pictures of all sides of the box here on the forum in case you're not able to figure it out.
MaHDi_011
Visitante
Thank you Rose
Now I have the same picture..
So tonight we will provide you with more images
Nabeel
Máster
Ok, so that may be the company.
You need to contact Comtel. Find their numbers and tell them that your phone is sim locked. Only they can provide you with the unlock code.
oMiD94
Visitante
Here you are
MaHDi_011
Visitante
Hello again heart
In Iran, there is no operator called Comtel
We have a number of Comtel not and do not think our answer to whether you can contact them to create and share our problems?
I think I've found her official site
 comtelmea.com/v1/lp/
Please do everything in your power to us
Special thanks to you
Nabeel
Máster
Hopefull Sony doesn't have a holiday today and I will try to find using your IMEI number, to what company is your phone locked and then we will contact them for the unlock code.
MaHDi_011
Visitante
We are very grateful that you're trying to address the problem Rose
1. We have no way to solve the problem but you do not and there is not Sony's official representative And I also have access to Dubai (Comtel) do not
Please join us as soon as possible as to Problem
special thanks
Nabeel
Máster
Hi
Looks like your mobile is not supposed to be locked.
Did you flash the CDA number 1297-9122 MENA Arabic, Customized MEA using flashtool ?
If not then try it one last time and see if it works.
If it doesn't, then you will have to send your phone to service center or contact comtel.
MaHDi_011
Visitante
Yes, by pressing again the problem remains
You went back to the organization?! Send us a phone to Dubai (Comtel) is not possible!
Please consider our other solutions
