Sound problem help
telf29
Sound problem help
Hello, about an hour a go my sony xperia z loud speaker has just gone really quite iv tried playing with all the setting but it is really quite when playing music or reciving a phone call can anyone help. (it never was this quite)
Hi Hi isjgthjhjm;lk
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Karan_wolverine
first of all if it is dipped or fallen in water let it dry out completely. At that tihme it is normal. After all te water dries out it will become normal. If it is not the case try reset only settings.(settings reset). If that alos didn work, its better to contact local sony support center
2 ODPOW. 2
Karan_wolverine
telf29
i tried out in water about 2 hours ago, just now it has gone back to normal i never relised after being in water it could effect the sound thank you.
(they should probley tell people about this i paniced, i thought i might have broken it)
