- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
What would you like to know about Xperia Z1 Compact?
Is there something you would like to know about the Xperia Z1 Compact?
Make a post if there is something that you would like for us to test.
And we will try to check this for you. :smileysmileythumbsup:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Why is the camera so bad when the flash is used! The bleed makes the photos look like something from crappy camera that came free with a tank of petrol in the 80's.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@plasticookies wrote:Does this phone have optical image stabilization?
It has image stabilizer that you can switch on and off if you set the camera to manual. Press the 3 dots on the bottom left of the screen, then scoll down, yo will see a slider to switch it on or off. I assume if the camera is set to auto, the image stabilizer is on.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
1. why is the camera so bad knowing that other companies use the Sony lenses and there pictures are looking great????
2. why does it heat up so much ????
3.when I've reset the phone i'm still having the same problems ????
4.I've backed up my phone now the phone won't accept the back-up I've made ????
5. why the screen cracks IT WASNT IN A POCKET OR IN A BAG IT WAS ON A TABLE NEXT TO MY BED WOKE UP CLEAN CRACK DOWN THE SIDE COULD NOT BELIEVE IT
really disappointed in this phone it is my second z1c gave it a chance when the first one i had problems sent it back (brought direct from sony btw) thought it would be the end of myself buying apple products but this experience is been so bad i know if there's a problem with the iphone there's a store near by or the tech support is a click/call away
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I do wonder if is optical and not software
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
is there a way to increase the sound with the headphones on?
XLoud is sort of like a placebo it increases the volume for the first 5 sec then decreases it to normal
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Start typing automatically when there is water drops on the screen
Pls let me know a solution
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
1- why you ignored the questions about the flash bleeding issue and the poor camera quality?
2-why you leave the topic opened for months while everyone is getting ignored?
Thank you Mr Johan.!
