palashs
Visitor
Xperia z freeze
it's been a month using Xperia z, but recently it has started freezing completely. not only while playing games but also while doing simple tasks as browsing. also the battery sucks after the update and stamina mode doesn't work. It's been a disappointment till now, I hope you guys fix all this in the next update.
1 ACCEPTED SOLUTION
Accepted Solutions
GeoffH
Enthusiast
hey you can install what you want Slightly_smiling_Face but I would strongly recommend not installing any utilities that try to manage things that are already being managed = there's every chance of a conflict and a crash
let me know if things have improved
regards
8 REPLIES 8
Arjun
Contributor
Repair your phone using sony update service
palashs
Visitor
done that already!
GeoffH
Enthusiast
make sure you have no task managers memory managers antivirus etc installed
remove the SD card
turn off stamina mode
check in the running apps for ironically apps that shouldn't be running and stop them or even uninstall them
to me you either have a hardware glitch or an app that is running in the background and freezing up
so the idea is to narrow it down as much as possible and take it from there
regards
palashs
Visitor
That should help, thanks. But does this mean that task managers and anti-virus aren't to be installed on the device?
Arjun
Contributor
There is usually no need to install antivirus and task mangers as they cause more problems rather than solving them Dizzy_Face
and xperia z has built in task manger the recent apps button works as a task manger from which you can close an app by just holding it
GeoffH
Enthusiast
regards
palashs
Visitor
Haha okay, will do that
palashs
Visitor
Yeah, it's been working better now I guess.... Thanks
