Hi, a yellow line has appeared in the top right hand corner of my screen. It is approx 20mm long and about 3mm wide. It is not a straight line. I want to send it off to Sony for repair under warranty but don't want them to use the excuse that the phone has been dropped as thats what was implied when i spoke to customer support. The phone has never been dropped or had a bang. I have tried the Software reset. Any advise would be appreciated. Thanks.
Solved! Go to Solution.
Hi pele35uk
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
If developer options is not turned on and the problem is persisting, then I can only advise that a service centre check the device.
There is no way to clarify over the phone or in a forum if this will be covered, this needs to be assessed. Please contact customer care again and ask for the handset to be checked.
I apologize for the inconvenience this may cause.
Hi pele35uk
Hi, yes it's turned on. Thanks
Did you manage to get this issue resolved pele35UK?
Hi, yes thank you. I sent it away to Sony and they replaced the display and the flex all FOC. Thanks
please i want to know if i have the same problem and the developer options is turned on , what can i do?
Disable developer options or go to settings-apps-all,scroll down to settings and clear data for the app.
thank you , but i think the only solution for this problem ( yellow line ) is to replace the lcd screen ) am right?
