Audio input only Sony BDV-N590
SOLVED
pickthalld
Explorer
Hi
I've worked through the manual but can't find or understand(!). i've got a new Smart TV and I want to watch iPlayer/Amazon/tuner on the TV and have the audio output played through the surround sound system. How can I do this without the system trying to take over the video feed? I want to use my HDMI cable.
thanks in advance
Daryl
1 ACCEPTED SOLUTION
Accepted Solutions
pickthalld
Explorer
Doing this identified that one of the TV HDMI ports was marked 'ARC'! Problem solved - thanks for your assistance.
11 REPLIES 11
profile.country.IT.title
Marino.Manolo
Genius
Hi,
you can if your TV has the HDMI ARC... Can you check this?...
Manolo
pickthalld
Explorer
thansk for the quick response - yes it does
  • HDMI A / Return Ch. Support
    Yes
Marino.Manolo
Genius
Ok, so... In your TV's MENU I think you have to find a SUB MENU for Audio customization and inside this, maybe, you are able to find a value for a choice between TV Speakers and Audio System...
Manolo
pickthalld
Explorer
Thanks - I've done that but the BDV keeps grabbing the video on the TV. When I turn on the TV, the BDV automatically turns on and then I lose my TV's picture as it switches to the BDV menu
Marino.Manolo
Genius
In TV's MENU you have, I think, a voice for Control for HDMI... Try to change the parameters inside for resolve this "issue"...
Manolo
pickthalld
Explorer
Thanks - I'm making progress!
When I select audio output [HDMI-Receiver] on the TV, it turns on the BDV and the video stays as live TV. The BDV displays 'TV' on the console but there is no sound coming out - even with volume turned up.
What do I need to do with BDV to play the sound?
Marino.Manolo
Genius
In the BDV have you choice the correct input?
And... Have you choice Auto in [System Settings] > [HDMI Settings] > [Audio Return Channel]?
Manolo
pickthalld
Explorer
BDV input is down as TV. The TV sound output is down as HDMI Receiver.
System settings as attached:IMG_4720.jpg
Marino.Manolo
Genius
The problem is that: All appears ok...
Try to unplug and plug the cables...
Manolo
