BDP-S6500 BLU-RAY PLAYER ADVICE.
NommyNom
New
I'm really not sure if I've put this in the correct section, so I hope I have..
Hello,
I recently btought the Sony BDP-S6500 blu-ray player and on the box it says 4k uhd, however under that it says 'upscale'.
What I am wondering is if this will play the new uhd 4K blu-ray discs?
1 REPLY 1
Anonymous
Not applicable
Hi there
Welcome to the forums :slight_smile:
No you didnt post your question in the right area - but that OK, I have moved it to the right spot and it should auto re-direct you to it anyhow.
Anyway, onto the answer - Upscaling basically converts a lower resolution video to a higher resolution - to 'look' like its higher resolution in order to display on a higher definition screen.  Basically the BDP-S6500 is faking a 1080p Bluray, upscaling this resolution to 2160p (or 4K) to display on a 4K screen.  It is not true 4K, therefore you also cannot play the newer 4K UHD Bluray Discs.
A better explaination than mine can be found:
http://www.makeuseof.com/tag/upscaling-how-does-it-work-and-is-it-worth-it/
If you want to play the newer 4K UHD Blurays, then you would need Sony's UBP-X800
Cheers
