KDL-50W829B Table Stand Height Adjustment?
Mowgli001
New
Hi,
I have just purchased a Sonos Playbar soundabar for my television. Unfortunately the soundbar is a bit high and obscures the bottom of the tv screen. I don't want to wall mount the tv. Is there a way of making adjustment to the stand height, I need to raise about 1 inch.
Many Thanks
2 REPLIES 2
Anonymous
Not applicable
Hi there
Unfortunately there is no 'off-the-shelf' product to increase the height of the TV stand provided.  So what you will need is a 'TV Riser'  If you search Amazon or on Google, you will find many examples of this.
However, I understand that the playbar features an IR Repeater@
Cheers
Darbo25
Member
Not sure of your location but if you're in the UK you can go to b and q or somewhere similar and buy one of them ' floating ' shelves,  come in plenty of colours to hopefully find a match and lifts it just enough to get over my centre speaker.
http://www.diy.com/departments/black-floating-shelf-l802mm-d237mm/1162418_BQ.prd
This what I used,  did the trick.
