Sky TV issues.. No signal HT-XTC3
L8JULP
Explorer
Hi, having intermittent issues when switching on Tv.
choosing HDMI1 but it's regularly showing 'no signal' for our Sky + box .  Will eventually connect  after switching between tv and hdmi1 for 5 mins. Really annoying had the box since Monday and not impressed.
Any advice is most welcome.  Thanks
2 REPLIES 2
Anonymous
Not applicable
Hi there
Some suggestions to try:
  • Have you tried connecting the Sky box directly to the TV instead of the HT-XT3?
  • Try disabling the HDMI-CEC on the Sky box itself.
  • Try another HDMI cable
Cheers
L8JULP
Explorer
Thank you for your reply, will give it a go. Both cables should be ok they are new. Most appreciated , J
